This procedure does not apply to VSP 8600 Series.About this task
View the AS-scope link-state advertisements.
- Select OSPF.
- Select the As Lsdb tab.
As Lsdb Field Descriptions
Use the data in the following table to use the As Lsdb tab.
| Name | Description |
| Type | Specifies the type of the link-state advertisement. |
| Lsid | Specifies the piece of the routing domain that the advertisement describes. |
| RouterId | Specifies the originating router in the Autonomous System. |
| Sequence | Specifies old and duplicate link-state advertisements. |
| Age | Specifies the age, in seconds, of the link-state advertisement. |
| Checksum | Contains the checksum of the complete contents of the advertisement, except for the age parameter. The checksum does not include the age parameter so that advertisement age increments without updating the checksum. |
| Advertisement | Specifies the size of the entire link-state advertisement. |
