This procedure does not apply to VSP 8600 Series.About this task
View the link-local advertisements for each virtual interface in the link-state database.
- Select OSPF.
- Select the Local Lsdb tab.
Local Lsdb Field Descriptions
Use the data in the following table to use the Local Lsdb tab.
| Name | Description |
| IpAddress | Specifies the IP address of the interface from which the link-state advertisement was received if the interface is numbered. |
| AddressLessIf | Specifies the interface index of the interface from which the LSA was received if the interface is unnumbered. |
| Type | Specifies the type of the link-state advertisement. |
| Lsid | Specifies the piece of the routing domain that the advertisement describes. |
| RouterId | Specifies the originating router in the Autonomous System. |
| Sequence | Identifies old and duplicate link-state advertisements. |
| Age | Specifies the age, in seconds, of the link-state advertisement. |
| Checksum | Contains the checksum of the complete contents of the advertisement, except for the age parameter. The checksum does not include the age parameter so that advertisement age increments without updating the checksum. |
| Advertisement | Specifies the size of the entire link-state advertisement. |
