Actions are active (selectable) or inactive (un-selectable) depending on the device type selected in the Show menu. Some actions are executed when you select a device and then select an action. In this case, no other input is required. Other actions will display a dialog that require more input. Descriptions of the actions are as follows:
| Action | Description |
Set Flag |
Allows you to flag the selected device(s) to indicate attention is required. |
Clear Flag |
Allows you to remove a flag from the selected device(s). |
Classification |
Sanctioned (inherit) Classify the selected device(s) as a sanctioned device that inherits its traits from wherever its location in the network tree. Sanctioned (override) Classify the selected device(s) as a sanctioned device using traits that override the inherited traits. For example, a security profile can be applied to a BSS that overrides the inherited traits. Sanctioned Classify the selected device(s) as sanctioned (Unknown Devices only) Unsanctioned Classify the selected device(s) as unsanctioned. Neighboring Classify the selected device(s) as a neighboring device. |
Client Type |
Classifies a Wireless Client as one of the following types:
Audit Devices |
Allows you to conduct a compliance audit on the selected device(s) (see < LINK HERE >.) |
Retrieve Diagnostic Logs |
Allows you to display the diagnostic logs for the selected device(s). If no logs are available, you will receive a message stating so (see < LINK HERE >.) |
Remove Devices |
Allows you to remove selected device(s) from monitoring (see < LINK HERE >.) |
Move Devices |
Allows you to place selected device(s) on a floor (see < LINK HERE >.) |
Upgrade Devices |
Allows you to upgrade the firmware for the selected device(s) (see < LINK HERE >.) |
Import CLI Variables |
Allows you to import CLI variables at the device level (see < LINK HERE >.) |
Export Devices |
Allows you to export information about selected device(s) to a CSV file (see < LINK HERE >.) |
Command Run and Log |
Allows you to execute CLI commands for selected device(s) and save results in a log file (see < LINK HERE >.) |
Search Device Configuration |
Allows you to search for device configurations on the network. |
Generate Tracker Files |
Allows you to generate tracker files and save the files to a directory on your computer |
