The AirWave switch drop-down menu contains functions that you can apply to the
selected AirWave switch. Click the drop-down menu button
next to
the AirWave switch name to display the drop-down menu.
The drop-down menu for AirWave devices contains the following functions:
| Function | Description |
Alarms |
Accesses the Alarms tab where you can view the alarms for the selected AirWave device. See Alarms for more information. |
Properties |
Opens the Properties overlay for the selected AirWave device. |
Upgrade |
Upgrade the firmware for the selected AirWave switch. See Upgrade Devices for more information. |
Rename |
Opens a dialog window to rename the selected AirWave device. |
Move |
Moves the selected AirWave device to another network level (floor). See Move Devices for more information. |
Remove |
Removes the selected AirWave device from your network. See Remove Devices for more information. |
Readiness Test |
Validates that the AirWave device is management ready (that is, it can be manage through ASDP). You are alerted of problem areas. See Readiness Test for more information. |
Device Polling |
Conduct a compliance audit on the selected AirWave switch. See Audit Devices for more information. |
Action Details |
Displays a table listing specific actions that are occurring to devices seen on your WLAN. |
Port Lookup (Scan all MACs) |
Scan MAC addresses to view a list of switch ports. See Port Lookup for more information. |
Forensic Analysis |
Opens the Forensic Analysis—Basic window for the specified AirWave switch. See Forensic Analysis-Basic for more information. |
Direct Connect |
Accesses the user interface (UI) for the selected AirWave device. |
Copy MAC |
Copies the MAC address of the selected AirWave device for later use. |
