Auto-Placement rules configure where devices are placed when
they are imported into the AirDefense managed network.
To edit an existing auto-placement rule:
From the Auto-Placement Rules screen,
select the auto-placement rule to edit.
Select the
icon to
edit the selected auto-placement rule.
The Auto Placement Rule
dialog displays.
Modify the required fields.
Select the Apply button located to the top
right of this dialog to save the auto-placement rule.
Select the small 'x' icon to the top left of the dialog to close it.
