BSS Tracking
For BSS tracking, the Enhanced Beacon table on the RFSX000 controller must be enabled.
  1. Log into the RFSX000.
  2. Navigate to Security > Enhanced Probe/Beacon Table > Beacon Table.
  3. Select the Enable Enhanced Beacon Table check box.
  4. In the Channel Set fields, enable the channels for each radio that you want to scan.
  5. Leave the default values for Scan Interval, Scan Time, and Maximum number of APs fields.
  6. Click Apply.
  7. Navigate to Network > Access Port Radios.
  8. Double-click on the B/G radio of the AP650.
  9. Repeat Step 9 and Step 10 for the A radio.
  10. Save the configuration.
  11. Restart the controller. (If you are going to enable the enhanced probe table, follow the directions provided below before restarting the switch.)
