You can view the properties of a WLSE by clicking the drop-down menu button
and
clicking Properties.
The following information is displayed:
| Field | Description |
Name |
The name of the WLSE. |
Description |
A description of the WLSE. |
Host Address |
The IP address of the WLSE. |
Flagged |
Flag a WLSE that you want to bring attention to. |
Observed Data |
Data that AirDefense Services Platform observed about the WLSE. You can filter the observed data by entering significant text in the Search field. |
The scope of the WLSE is shown under the Scope tab. The Autoplace button can be used to place the WLSE in a network folder using Auto-Placement rules.
Alarms related to the WLSE are shown in the Alarms tab. The Actions button can be used to perform one of the listed functions on a selected (highlighted) alarm.
You can view and/or override an WLSE's configuration by selecting Communication Settings. These configuration settings are all located in the Configuration Tab.
You can display valid licenses for a WLSE by selecting License.
If you make changes, click Save to save them.
Click the Delete Device button to delete a device from your network.
Click the i button X to close the Properties overlay.
