Live View has four user adjustable settings. They are:
| Setting | Description |
Capture Size Limit |
Sets the maximum amount of frames that can be captured during any one session. |
Capture Management Frames |
Sets the Live Monitoring sessions to capture management frames. If selected, you can also truncate management frames to a specific number of bytes or have no truncation. |
Capture Control Frames |
Sets the Live Monitoring sessions to capture control frames. If selected, you can also truncate control frames to a specific number of bytes or have no truncation. |
Capture Data Frames |
Sets the Live Monitoring sessions to capture data frames. If selected, you can also truncate data frames to a specific number of bytes or have no truncation. |
To change the settings:
