The APs drop-down menu contains functions that you can apply to
the selected AP. Click the drop-down menu button
next to the AP name to display the
drop-down menu.
The drop-down menu for APs contains the following functions:
| Function | Description |
Alarms |
Accesses the Alarms tab where you can view the alarms for the selected AP. See Alarms |
Properties |
Opens the Properties overlay for the selected AP. |
Upgrade |
Upgrades the firmware for the selected AP. (For more information, see Upgrade Devices.) |
Rename |
Opens a dialog window to rename the selected AP. |
Move |
Moves the selected AP to another network level (floor). (See Move Devices for more information.) |
Remove |
Removes the selected AP from your network. (See Remove Devices for more information.) |
Readiness Test |
Validates that the AP is management ready (that is, it can be manage through ASDP). You are alerted of problem areas. (See Readiness Test for more information.) |
Device Polling |
Conducts a compliance audit or a data poll on the selected AP. (See Audit Devices for more information.) |
Action Details |
Displays a table listing specific actions that are occurring to devices seen on your WLAN. |
Port Lookup |
This feature is disabled unless you have a WIPS license. |
Forensic Analysis |
Opens the Forensic Analysis - Basic window for the specified . |
Direct Connect |
Accesses the user interface (UI) for the selected device. |
Copy MAC |
Copies the MAC address of the selected for later use. |
