Once you have defined an Alarm Action Manager template, to use it, you must apply it to your system. To apply a template, you must first select the Enable configuration check box.
You may select multiple Alarm Action Manager templates by checking more than one check box.You should always apply an Alarm Action Manager template at the appliance level. When you do, the profile is inherited for all the other levels. Then, if you have a level that needs a different Alarm Action Manager template, you can apply that template to that level. For example, in the above screen shot, the Alarm Action Manager template for the appliance is the Action_Manager-Corporate template and then for a special case (in the following screen shot) you could override the Alarm Action Manager template at the ADSP level and apply the Action_Manager-Guest template to the Sanctuary Park network level.
The Override settings option is available when you select (highlight) a network level below the appliance level. Use the Expand
button
to reveal the other levels.
You can copy Alarm Action Manager templates to all your appliances by clicking the Copy settings to all appliances button.
You must have a Central Management license in order to copy settings to all appliances.Click the Apply button to save your changes. Click the Reset button to discard your changes.
