The WLSE drop-down menu contains functions that you can apply to the selected WLSE.
Click the drop-down menu button
next to
the WLSE name to display the drop-down menu.
The drop-down menu for WLSE devices contains the following functions:
| Function | Description |
Alarms |
Accesses the Alarms tab where you can view the alarms for the selected WLSE device. See Alarms for more information. |
Properties |
Opens the Properties overlay for the selected WLSE device. |
Rename |
Opens a dialog window to rename the selected WLSE device. |
Move |
Moves the selected WLSE device to another network level (floor). See Move Devices for more information. |
Remove |
Removes the selected WLSE device from your network. See Remove Devices for more information. i |
Readiness Test |
Validates that the WLSE device is management ready (that is, it can be manage through ASDP). You are alerted of problem areas. (See Readiness Test for more information.) |
Action Details |
Displays a table listing specific actions that are occurring to devices seen on your WLAN. |
Direct Connect |
Accesses the user interface (UI) for the selected WLSE device. |
Copy MAC |
Copies the MAC address of the selected WLSE device for later use. |
