A Communication Profile is a set of configurations that enables you to use the same settings for connecting to various devices in your AirDefense managed network.
To add a new communication profile:
The Communication Profile dialog displays.
By default, the SNMP configuration tab displays.
| Field | Description |
| Enable SNMP Settings | Select this switch to enable SNMP settings. |
| SNMP Port | Use the spinner to set the SNMP port for the device. The default port number is 161. |
| Timeout (in ms) | Use the spinner to set the timeout value in milliseconds to connect to the device. |
| Retries | Use the spinner to set the maximum number of retires that can be made while attempting to connect to the device. |
| Version | Use the drop-down to select the SNMP version number to use. AirDefense supports SNMP version 1 (V1), version 2 (V2), and version 3 (V3). |
| Read Community | Enter the Read Community string. This string is used for SNMP authentication. You also have an option to display passwords while typing them. |
| Write Community | Enter the Write Community string. This string is used for the SNMP authentication. |
| User | Enter the name of the SNMP V3 user.
This user is configured on the switch
for SNMP V3 access. Note:
This field is only available when SNMP
version is V3.
| Auth. Algorithm | Use the drop-down list to select the
authentication algorithm. This selection
must match what is set on the device.
The available algorithms are
MD5,
SHA, and
None. You must supply
a pass-phrase which must also match what
is set on the device. Note:
version is V3.
| Priv. Algorithm | Use the drop-down list to select the
privacy algorithm. This selection must
match what is set on the device. The
DES,
3DES,
AES128,
AES192,
AES256, and
none. You
must also supply a pass-phrase which
must also match what is set on the
device. Note: This field is
only available when SNMP version is
V3.
Provide the following information:
| Enable Console Settings | Select this switch to enable Console settings. |
| User | Use this field to enter the user name used to log in to the device. |
| Password | Use this field to enter the password for the above user name. Use the Show Password checkbox to view the password entered in this field. |
| Enable Password | Use this field to enter the Enable password. This password is required to enter the enable mode on the device. |
| Protocol | Use the drop-down list to select the protocol to use for console access. Select from SSH or Telnet. |
| Port | Use this field to enter the port number that is used for communications. By default port 22 is used used. |
| Enable HTTP Settings | Select this switch to enable HTTP settings. |
| Password | Use this field to enter the password for the above user name. |
| Protocol | Use the drop-down list to select the protocol to use for HTTP access. Select from HTTP or HTTPS. |
| Port | Use this field to enter the port number that is used for communications. By default port 80 is used used. |
