Zero Touch WLAN Infrastructure
Deployment
Zero Touch configuration enables taking WLAN infrastructure products directly out of
the box and plugging it into the network for operational use.
By coordination with the management platform, the infrastructure is able to
automatically receive the configuration needed to allow it to be used for
operational needs. This process eliminates the need for any manual configuration or
staging and thereby greatly simplifying deployments of WLAN infrastructure for
client access and sensors. Zero Touch works through a simple 3 step process.
- Infrastructure boots and sends a
trap to AirDefense to notify it that a new device is available on the network.
- AirDefense receives the trap and
recognizes that the trap is from an unknown device. AirDefense will perform a single
device discovery to import the newly added device into the management platform.
- Once placed in the management
tree hierarchy at the appropriate location, the system automatically pushes a
configuration template to the new device setting the appropriate configuration
for that device. Once the device imports the configuration, it is now fully up
and operational without any manual staging or configuration.
