Import New Certificate
The Trusted Certificates store contains certificates from other parties (like AirDefense kAppliances, LDAP or Radius Servers) that you expect to communicate with, or from Certificate Authorities that you trust to identify other parties. Follow these steps to install a trusted certificate:
  1. Click the Import New button. The Import New Certificate window displays.
  2. Click the Browse button to open the Select file to upload window.
  3. Navigate to the trusted certificate, select (highlight) it, and then click the Open button. The file name should now display in the Select field.
  4. Type in a name for the certificate.
  5. Click OK.
