To export information about your devices to a CSV file on your local workstation, select a device and click Export Devices from the Actions menu. A pop-up box asks you to confirm the download.
Click OK to confirm or click Cancel to exit without exporting the device(s).
When you click OK, a dialog window opens where you can specify the directory (folder) and name of the CSV file.
At this time, files exported using Export Devices are for external viewing only. They cannot be imported back into AirDefense.
AirDefense names the CSV file devices.csv by default. You can keep that name or change it.
Click Save button to save the CSV file. Click Cancel to exit without saving the file. Once the file is saved, you can view the file at any time.
