To access the Web Reporting web site, log in to the GUI and then select Menu > Reports. The report names are displayed by category. Select the desired report and click on the link to display it. The Web Reporting interface consists of three tabs: Reports, Published and Favorites.
To move from one page to another, click the tab name. See the following list for a description of each tab.
Published-The Published tab lists the reports that you have run, saved as a published report or have scheduled to run periodically. You cannot view a report published by another user unless that user shares the report. Once a report is published, you can:
Favorites-The Favorites tab is where you save reports that you run often. When a report is designated as a favorite, you can:
The Online Help describes each of these tabs in detail and explains how to create reports, add reports to the Favorites tab, and schedule reports.
