After conducting a Spectrum Analysis, you can save the temporary spectrum data to a permanent file on the appliance or to a file on your workstation. To save a file, you must first stop the Spectrum Analysis and then select File > Save from the Spectrum View window to display the Save Spectrum Data pop-up window.
You can access the saved spectrum data by selecting Menu > Open > Spectrum Analysis and then selecting the spectrum analysis file. The spectrum data is displayed in the Spectrum View window.
The Spectrum View window is opened minus the buttons and menus that are needed for generating spectrum analysis data.
