You may specify one or more actions to run when certain conditions are met as defined by the filter(s). Valid actions are:
When an action is selected, an Edit button is displayed. Click the Edit button to configure the action. Configuration will be different for each type of action. For example, selecting Classify Devices as your action displays the following dialog window.
Classify Devices allows you to classify devices as: Sanction (Inherit Profiles), Unsanctioned, Neighboring, or Sanction (Assign Profiles). Click the Save and Close button to save the configuration and exit the dialog window.
The following screen shot shows an example of a fully defined filter and action.
You can remove an action by clicking the x next to the action.
Click the Save and Close button to save the rule set and exit the window.
