UIPORT is used to display the network port that must be used to access the
                dashboard.
                     Type UIPORT at the command prompt to display the network port the GUI is
                        currently using. The UIPORT screen displays the current UI port used for
                        dashboard access.
                     Press [Enter] to return to the previous screen.
