The Passwords tab is used to specify the passwords to access devices.
The following fields are available:
| Field | Description |
Encrypt Passwords and Keys on Flash |
Select checkbox to encrypt passwords and keys on flash. |
Enable Password |
Specify (set) the enable password. Must be supplied in order to enter the enable mode. |
User Accounts |
Specify (add) additional user accounts using the Add button. You must specify a username and password. |
