Relay servers are devices in your network from which devices obtain configuration, firmware, and provisioning information.
Relay server is an option that is available with the WLAN Management license. This option does not appear if you do not have the above license.
Extreme AirDefense provides the ability to define both an external and an internal relay server. The Extreme AirDefense appliance can itself act as a relay server (internal relay server) for all the devices in its managed network.
It is recommended that relay servers are configured at the appliance level of the network hierarchy. To configure a different relay server to a particular scope (location),
select the context from the Structure & Tags
area. If the relay servers for this level are inherited from its parent, change the
control to Override. Configure a
different relay server to enable it for the selected context.
