Discovery profiles configure how devices are discovered or imported into the Extreme AirDefense managed network.
To add a new discovery profile:
The Discovery Profile dialog displays.
| Option | Description |
| SNMP Discovery | Configure device imports through SNMP Discovery. |
| Local File | Import devices via a local file. |
| Remote File | Import devices via a remote file. |
| XCC Import | Import device information from Extreme AirDefense. |
| XIQ Import | Import device information fromExtremeCloud IQ. |
From the Network Criteria selection drop-down list, select the criteria used to select the device.
10.9.*.100.192.168.12.23.192.168.10.10-192.168.10.35.192.168.10.0/24.www.example.com.Use the Communication Profile field to select an existing communication profile. From the drop-down list, you can select a existing communication profile, or you can create a new profile. You can also select the Manual Entry option from this list to create a communication profile that is unique to this SNMP host.
A communication profile is a set of parameters that enables you to connect to a remote server. For more information on communication profiles, see Communication Profile.Provide the following information:
| Field | Description |
| Host | Provide the host name or IP address of the remote server where the import file is located. |
| Protocol | From the drop-down list, select the protocol to use when communicating with the remote host. |
| Path | Enter the full path to the import
file on the remote host. The path must
also include the full name of the import
file. For example /home/localadmin/temp/importlist.list |
| User | Enter the username to be used when connecting to the remote host. |
| Password | Enter the correct password for the username entered in the User field. |
| Verify Server Certificate | Select this option to force Extreme AirDefense to verify the remote server's security certificate for validity. |
