The Security tab is where you define the security aspects of your WLAN Profile.
Complete the required fields as follows:
| Field | Description |
Authentication |
Specify the type of authentication devices may use (Open, Shared, WPA, WPA PSK, WPA2, WPA2 PSK, or Legacy EAP). |
Encryption |
Specify the type of encryption devices may use (Static WEP, WEP64, WEP128, TKIP, CCMP, or Keyguard). You may select one or more encryption types. |
WEP Keys |
Specifies the WEP keys used to connect to the network. The WEP key may be ASCII or hexadecimal. You may also elect to transmit the WEP key. Check the Display Passwords check box to display the passwords in plain text. Use the Add button to add a new key or the Delete button to delete a key. |
RADIUS Servers |
Note: This field is displayed only when the authentication method is
WPA, WPA2, or Legacy EAP.
Lists any RADIUS servers used in authentication. You can edit or
delete a highlighted server by clicking the appropriate button.
You can add new servers by clicking the New Server button which
displays the following overlay:
![]() You must supply the following information:
Click Save to save the RADIUS server information. |
