Add Licenses
Use the License Configuration screen to add new feature license to this AirDefense instance.
  1. Select the icon located to the top right of this screen.
    The License Verify screen displays.
  2. Select the Browse button to load the feature license using the operating system's File Upload dialog. Navigate to the location where your license file is stored and upload it to the AirDefense system.
    The OK, Verify License button enables.
  3. Select the OK, Verify License button to verify the license's validity for use with this AirDefense system.
    If the license is found to be valid, then the feature is added to the AirDefense system and the licensed feature becomes available through the AirDefense user interface.
  4. Use the Cancel button to exit without adding the license to your AirDefense system.
