The following fields are available when importing local files:
| Field | Description |
Job Type |
Import Local File |
Descriptions |
System generated description. You may change if you want to. |
Path |
Browse to specify a path on your local workstation including the import filename (e.g., c:\temp\filename) |
Select a sample CSV file |
Selects a sample CSV file from the drop-down list. Once a file is selected, click Open in New Window. A new window is opened containing the selected file. You can copy this file and use it to create an import file. |
Add to appliance |
Appliance where you want to import device (will only list your appliance unless you have a Central Management license) |
Device placement |
You have the option of using the auto-placement rules or selecting a folder from your network tree. |
