Network devices access relay servers to obtain configuration, firmware and provisioning information.
Relay Server is an option that is included with a WLAN Management license. If you do not have a WLAN Management license, Relay Server does not appear in the list of features and the features are renumbered.Define or update the relay servers used to access managed devices. Use the Relay Server screen to set the configurations of both the Device Relay and Appliance Relay Servers.
You may configure the relay servers at the appliance network level all the way down to the floor network level, but you should always configure the relay servers at the appliance level. Any network level below the appliance level will inherit the configuration. If you need to have a different configuration below the appliance level, use the Override settings option.
The Override settings option is available when you select (highlight) a network level below the appliance level. Use the Expand
button to reveal
the other levels.
