From the Alarm Action Manager screen, click New Template to configure a new action rule.
In the Action Rule field, give your action rule a name and select the Enable profile checkbox to enable the action rule.
The Action Rule Template window has four tabs that are used to define an Action Rule: Alarms, Actions, Advanced Filter, and Description. Use each of these to configure the action rule.
