The Alarm Type filter allows you to view devices by alarm type. Devices are grouped together according to their alarm threat to your network.
You have the option of displaying all alarm types or filtering alarms by a specific type. The different alarm types are:
Click the Edit button to select the alarm types that you want to display.
Click Edit, select the alarm type(s), and then click OK. The following graphic shows that you only want to display rogue alarms.
To remove an alarm type, select (highlight) the alarm type and click Remove.
