Define the Client Based Settings for your Location Based Services profile using the following fields found in the Presence Settings tab:
| Field | Description |
Enable all Presence enter events |
Enables the enter events that alerts ADSP that a device has entered the premises. Three enter events are available. Each enter event includes a RSSI threshold (in dBms) in which the device would have to exceed before triggering the presence event. |
API preset event frequency |
Enables the API preset event frequency. Set frequency between 1- 120 minutes or 1 - 59 seconds. |
Presence age out |
Sets the time span that a device's location is aged out of the system. Valid entries are 1 - 120 minutes. |
Enable Presence exit events |
Enables the exit events that alerts ADSP that a device has left the premises. |
