Use the Command Run and Log action to run CLI commands on devices that are in the Audit mode (not template based) and then store the results in a log file for viewing later.
In order for Command Run and Log to work properly, Communication Settings Profile must exist for the affected devices.
The commands are applied to all devices selected in the Network tab. Selected devices are listed in the Devices that will be affected field.
Each command must be on a line by itself. If a command requests a confirmation from a device, ADSP will respond Yes.
You may import an updated configuration from device(s) after a command has run successfully. Just select the Import checkbox.
The logs for the Command Run and Log are placed at: /usr/local/smx/device-mgmt/jobs. For each job, there is a job ID. The interaction with all devices for a job is placed in a sub-folder whose name is the job ID number. Click Submit to run the commands. Click Cancel to exit without running any commands.
You can check the job status by navigating to Configuration > Operational Management > Job Status. While viewing the job details, you can view the logs by selecting a device and then clicking the View Log link.
You can view the log of another device by selecting the device from Devices drop-down menu. Click Copy to Clipboard to copy the log contents to the clipboard. Click Cancel to exit the log.
