You can enable reboot on a system error by following these steps:
Type panic at the command prompt. A message is displayed to alert you the
reboot on system error is not currently enabled.
At the prompt, type e to enable reboot on system error.
Type q to return to the Config menu. You are prompted to save your
changes.
Type yes and press [Enter] to save your changes (or no to disregard
your changes).
Press [Enter] to display the Config menu.
