The Email action enables you to configure the parameters for sending emails when there are some devices that meet the conditions specified in the Filters tab.
By default, an empty template is made available for immediate use. Use this empty template to create your first email. To add additional emails, use the green + icon to add a new Email action. When you add a new email action, a new block is created for it along with a blank template.
Multiple Emails can be generated for a Device Action Manager rule set.
Hover on the Email box to view a synopsis of its configuration.
For each email, provide the following information:
| Field | Description |
| To | The email addresses of the recipients for this email. Add multiple email addresses separated with a semi-colon (;) sign. |
| From | The email address that is used to send this email. This is the address that will receive any reply mails received from the recipients. |
| Subject | The subject for this email. |
| Priority | Use the drop-down list to select the priority of this mail. |
