Use the following procedure to view IPv6 Mroute information for an interface.
- In the navigation pane, expand the following folders: .
- Click IPv6 Mroute.
- Click the Interfaces tab.
Interfaces field descriptions
Use the data in the following table to use the Interfaces tab.
| Name | Description |
| IfIndex | Displays the slot and port number or VLAN ID for this entry. |
| Ttl | Displays the datagram time-to-live (TTL) threshold for the interface. IPv6 multicast datagrams with a TTL less than this threshold are not forwarded out of the interface. The default value of 0 means that all multicast packets are forwarded out of the interface. |
| Protocol | Displays the protocol as one of the following:
