Enable Protocol Independent Multicasting (PIM) on a CLIP interface so that it can participate in PIM routing.
- You must globally enable PIM.
This procedure does not apply to XA1400 Series and VSP 4450 Series.
Circuitless PIM field descriptions
Use the data in the following table to use the Circuitless PIM tab.
| Name | Description |
| Enable | Enables PIM on the CLIP interface. |
| Mode | Specifies the PIM mode. |
