Perform this procedure to configure scheduled time intervals during which the switch will operate in low power state. This time interval can be for a week, weekend, or individual days.
You can configure a maximum of 84 entries in the Energy Saver schedule.
                    If you have previously enabled Energy Saver globally, you must disable it globally before creating a schedule.
                    If you have previously enabled Efficiency Mode, you must disable it before creating a schedule. You cannot change the default Efficiency Mode schedule entries when Efficiency Mode is enabled.
                    You must enable Energy Saver on every port affected by the schedule.
Switch:1>enable Switch:1# configure terminal Switch:1(config)#energy-saver schedule weekend 0735 activate Switch:1(config)#energy-saver schedule monday 0600 deactivate
What to do next
Enable Energy Saver globally.
The following table defines parameters for the energy-saver schedule command.
| Variable | Value |
| {activate | deactivate} | Activates or deactivates the scheduled event. |
| <hhmm> | Specifies the hour and minutes to enable Energy Saver feature on the switch. |
| {friday | monday | saturday | sunday | thursday | tuesday | wednesday | weekday | weekend} | Specifies the day(s) to enable Energy Saver feature on the switch. |
