This procedure only applies to the VSP 7400 Series.
Perform this procedure to view the UNI ports associated with particular remote IP multicast routes.
- Select SPBM Remote.
- Select the IpMcastRoutes tab.
- Select an entry.
- Select the UNI Ports button.
IpMcastRoutes-Uni Ports Field Descriptions
Use data in the following table to use the IpMcastRoutes-Uni Ports tab.
| Name | Description |
| VsnIsid | Specifies the VSN I-SID. Layer 2 VSN and Layer 3 VSN each require a VSN I-SID. |
| Group | Specifies the group IP address for the IP Multicast over Fabric Connect route. |
| Source | Specifies the IP address where the IP Multicast over Fabric Connect route originates. |
| NickName | Specifies the nickname. |
| EgressVlan | Specifies the egress VLAN of the IP multicast route. |
| EgressActivePorts | Specifies the egress active ports. |
