| Feature | Product | Release introduced |
| Key Health Indicator (KHI) | VSP 4450 Series | VSP 4000 4.0 |
| VSP 4900 Series | VOSS 8.1 | |
| VSP 7200 Series | VOSS 4.2.1 | |
| VSP 7400 Series | VOSS 8.0 | |
| VSP 8200 Series | VSP 8200 4.0 | |
| VSP 8400 Series | VOSS 4.2 | |
| VSP 8600 Series | VSP 8600 4.5 | |
| XA1400 Series | VOSS 8.0.50 |
The Key Health Indicators (KHI) feature provides a subset of health information that allows for quick assessment of the overall operational state of the device.
KHI was not designed to provide a comprehensive debugging solution. Instead, KHI identifies key information that could lead support personnel towards discovery of a specific failure. After the technician assesses the KHI information, further debugging is required to determine the specific reason for the fault.
You should capture KHI information during normal operations to provide a baseline for support personnel when detecting fault situations.
