Deleting a username
DEMO FEATURE - Multiple CLI Users Per Role is a demonstration feature on some products. Demonstration features are provided for testing purposes. Demonstration features are for lab use only and are not for use in a production environment. For more information on feature support, see VOSS Feature Support Matrix.
Use this task to delete a username. Default ro, rw, and rwa users cannot be deleted.
You must use an account with read-write-all privileges to delete a user.
Delete a user:
Switch:1>enable Switch:1#configure terminal Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#no username smith The specified username will be deleted! Contiune (y/n) ? Y Switch:1(config)#show cli username smith Username does not exit
The following table defines parameters for the no username command.
| Variable | Value |
| WORD <1–20> | Specifies the username to delete. |
| enable | Disables the username. |
