This procedure only applies to the VSP 7400 Series.
Ensure that you enable DvR on the node.
Perform this procedure to view all remote DvR routes on a Controller or a Leaf node.
The Controller node displays all the IP subnet routes configured for that DvR domain. A Leaf node displays all IP subnet routes learned from the Controller(s) for the Layer 2 VSNs in the DvR Domain. It also displays the Host Routes (ARPs) learned from other DvR enabled nodes.
- Select DVR Remote.
- Select the Database tab.
- Optional: To filter the rows based on the specific criteria, click Filter.
Database Field Descriptions
Use the data in the following table to use the Database tab.
| Name | Description |
| DestIpAddrType | Specifies the address type of the IPv4 destination address of the DvR database entry. |
| DestIpAddr | Specifies the IPv4 destination address of the DvR database entry. |
| DestMask | Specifies the destination mask of the DvR database entry. |
| L3Isid | Specifies the Layer 3 I-SID of the DvR database entry. |
| EcmpIndex | Specifies the ECMP index for the DvR database entry. |
| NextHop | Specifies the MAC address of the next hop BEB, in the DvR database entry. |
| L2Isid | Specifies the Layer 2 I-SID of the DvR database entry. |
| VrfId | Specifies the VRF ID for the DvR database entry. |
| OutgoingInterface | Specifies the outgoing interface (port or MLT) of the DvR database entry. |
| SpbCost | Specifies the SPB cost of the DvR database entry. |
| PrefixCost | Specifies the prefix cost of the DvR database entry. |
| NextHopName | Specifies the host name of the next hop BEB, in the DvR database table entry. |
| Age | Specifies the uptime since creation of the DvR database table entry. |
