Use the following procedure to configure the format of the RADIUS password when authenticating NEAP MAC addresses using RADIUS.
The following table defines parameters for the eapol multihost non-eap-pwd-fmt command.
| Variable | Value |
| ip-addr | Management ip-address of the switch. |
| key WORD<1-32> | Key value used for non-eap password format. |
| mac-addr | Mac-Address of the client. |
| padding | Includes a dot in the RADIUS password for every missing parameter. |
| port-number | Index of the port on which MAC is received. |
To derive the port number for an interface, use the command show interfaces gigabit [{slot/port[/sub-port][-slot/port[/sub-port]][,...]}] .
If you configure interface 1/6 on the product, to derive the port-number for this interface, use the command show interfaces gigabitEthernet 1/6. From this command, you can ascertain that port number used in the NEAP password is 197.
Switch:1(config)# show interfaces gigabitEthernet 1/6
                                      Port Interface
PORT                            LINK  PORT           PHYSICAL          STATUS
NUM      INDEX DESCRIPTION      TRAP  LOCK     MTU   ADDRESS           ADMIN  OPERATE
1/6      197   1000BaseTX       true  false    1950  f8:15:47:e1:dd:05 up     up
