Viewing ACL Statistics
Graph statistics for a specific ACL ID to view default statistics.
- Click Advanced Filters (ACE/ACLs).
- Click the ACL tab.
- Select an ACL.
- Click Graph.
- You can click Clear Counters to clear the Statistics fields.
Statistics Field Descriptions
Use the data in the following table to use the Statistics tab.
Based on your hardware platform, the output can display the ACL packets by ACE type or Primary Bank or Secondary Bank.
| Name | Description |
| AclId | Specifies the ACL ID. |
| MatchDefaultSecurityPkts Note:
                                     Exception: not supported on VSP 7400 Series. | Shows a security packet count of traffic that does not match an ACE rule or hits the default action if count is configured in the ACL global action. |
| MatchDefaultPrimaryBankPkts Note:
                                     Exception: only supported on VSP 7400 Series. | Shows a Primary Bank packet count of traffic that does not match an ACE rule or hits the default action if count is configured in the ACL global action. |
| MatchDefaultSecurityOctets Note:
                                     Exception: not supported on VSP 7400 Series. | Shows a security byte count of traffic that does not match an ACE rule or hits the default action if count is configured in the ACL global action. |
| MatchDefaultPrimaryBankOctets Note:
                                     Exception: only supported on VSP 7400 Series. | Shows a Primary Bank byte count of traffic that does not match an ACE rule or hits the default action if count is configured in the ACL global action. |
| MatchDefaultQosPkts Note:
                                     Exception: not supported on VSP 7400 Series. | Shows a QoS packet count of traffic that does not match an ACE rule or hits the default action if count is configured in the ACL global action. |
| MatchDefaultSecondaryBankPkts Note:
                                     Exception: only supported on VSP 7400 Series. | Shows a Secondary Bank packet count of traffic that does not match an ACE rule or hits the default action if count is configured in the ACL global action. |
| MatchDefaultQosOctets Note:
                                     Exception: not supported on VSP 7400 Series. | Shows a QoS byte count of traffic that does not match an ACE rule or hits the default action if count is configured in the ACL global action. |
| MatchDefaultSecondaryBankOctets Note:
                                     Exception: only supported on VSP 7400 Series. | Shows a Secondary Bank byte count of traffic that does not match an ACE rule or hits the default action if count is configured in the ACL global action. |
| MatchGlobalSecurityPkts Note:
                                     Exception: not supported on VSP 7400 Series. | Shows a security packet count of traffic that matches an ACE rule or hits the default action if count is configured in the ACL global action. |
| MatchGlobalPrimaryBankPkts Note:
                                     Exception: only supported on VSP 7400 Series. | Shows a Primary Bank packet count of traffic that matches an ACE rule or hits the default action if count is configured in the ACL global action. |
| MatchGlobalSecurityOctets Note:
                                     Exception: not supported on VSP 7400 Series. | Shows a security byte count of traffic that matches an ACE rule or hits the default action if count is configured in the ACL global action. |
| MatchGlobalPrimaryBankOctets Note:
                                     Exception: only supported on VSP 7400 Series. | Shows a Primary Bank byte count of traffic that matches an ACE rule or hits the default action if count is configured in the ACL global action. |
| MatchGlobalQosPkts Note:
                                     Exception: not supported on VSP 7400 Series. | Shows a QoS packet count of traffic that matches an ACE rule or hits the default action if count is configured in the ACL global action. |
| MatchGlobalSecondaryBankPkts Note:
                                     Exception: only supported on VSP 7400 Series. | Shows a Secondary Bank packet count of traffic that matches an ACE rule or hits the default action if count is configured in the ACL global action. |
| MatchGlobalQosOctets Note:
                                     Exception: not supported on VSP 7400 Series. | Shows a QoS byte count of traffic that matches an ACE rule or hits the default action if count is configured in the ACL global action. |
| MatchGlobalSecondaryBankOctets Note:
                                     Exception: only supported on VSP 7400 Series. | Shows a Secondary Bank byte count of traffic that matches an ACE rule or hits the default action if count is configured in the ACL global action. |
| DefaultGreenBytes Note:
                                     Exception: Only supported on VSP 4900 Series, VSP 7400 Series. | Shows byte count of traffic sent with a rate lower than committed-rate matching any of the ACE rules or hits on Default Action. |
| DefaultGreenPackets Note:
                                     Exception: Only supported on VSP 4900 Series, VSP 7400 Series. | Shows packet count of traffic sent with a rate lower than committed-rate matching any of the ACE rules or hits on Default Action. |
| DefaultYellowBytes Note:
                                     Exception: Only supported on VSP 4900 Series, VSP 7400 Series. | Shows byte count of traffic sent with a rate lower than peak-rate and higher than committed-rate matching any of the ACE rules or hits on Default Action. |
| DefaultYellowPackets Note:
                                     Exception: Only supported on VSP 4900 Series, VSP 7400 Series. | Shows packet count of traffic sent with a rate lower than peak-rate and higher than committed-rate matching any of the ACE rules or hits on Default Action. |
| DefaultRedBytes Note:
                                     Exception: Only supported on VSP 4900 Series, VSP 7400 Series. | Shows byte count of traffic sent with a rate higher than peak-rate matching any of the ACE rules or hits on Default Action. |
| DefaultRedPackets Note:
                                         Exception: Only supported on VSP 4900 Series, VSP 7400 Series. | Shows packet count of traffic sent with a rate higher than peak-rate matching any of the ACE rules or hits on Default Action. |
