Configure the IP routing protocol stack to determine which routing features the switch can use.
  1. In the navigation tree, expand the following folders: Configuration > IP.
  2. Select IP.
  3. Select the Globals tab.
  4. To globally enable routing, select Forwarding.
  5. To globally configure the default TTL parameter type a value in the DefaultTTL field.
    This value is placed into routed packets that have no TTL specified.
  6. To globally enable IPv4 ICMP broadcast, select IcmpEchoBroadcastRequestEnable.
  7. To globally enable IPv4 Fragmented ICMP packet filtering, select IcmpDropFragmentsEnable.
  8. To globally enable the Alternative Route feature, select AlternativeEnable.
  9. To globally enable ICMP Router Discovery, select RouteDiscoveryEnable.
  10. To globally enable IP Sorce Routing, select SourceRouteEnable.
  11. To globally enable ECMP, select EcmpEnable.
  12. Configure the remaining parameters as required.
  13. Select Apply.
Use the data in the following table to use the Globals tab.
Name
Description
Forwarding
Configures the system for forwarding (routing) or for dropping. The default value is forwarding.
DefaultTTL
Configures the default time-to-live (TTL) value for a routed packet. TTL indicates the maximum number of seconds elapsed before a packet is discarded. Enter an integer from 1 to 255. The default value of 255 is used if a value is not supplied in the datagram header.
ReasmTimeout
Specifies the maximum number of seconds that received fragments are held while they wait for reassembly. The default value is 30 seconds.
ICMPUnreachableMsgEnable
Enables the generation of Internet Control Message Protocol (ICMP) network unreachable messages if the destination network is not reachable from this system. These messages help determine if the system is reachable over the network. The default is disabled.
Important:
As a best pactice, enable icmp-unreach-msg only if it is absolutely required. If icmp-unreach-msg is enabled and a packet is received for which there is no route in the routing table, CPU utilization can dramatically increase.
ICMPRedirectMsgEnable
Enables or disables the system sending ICMP destination redirect messages.
Enables or disables IP ICMP echo broadcast request feature. The default is enabled.
Note: Exception: Not supported on VSP 8600 Series and XA1400 Series.
Enables or disables IPv4 Fragmented ICMP packet filtering globally. The default is disabled.
AlternativeEnable
Globally enables or disables the Alternative Route feature.
If the alternative-route parameter is disabled, all existing alternative routes are removed. After the parameter is enabled, all alternative routes are re-added. The default is enabled.
Enables the ICMP Router Discovery feature. The default is disabled (not selected). Use ICMP Router Discovery to enable hosts attached to multicast or broadcast networks to discover the IP addresses of neighboring routers.
AllowMoreSpecificNonLocalRouteEnable
Enables or disables a more-specific nonlocal route. If enabled, the system can enter a more-specific nonlocal route into the routing table. The default is disabled.
SuperNetEnable
Enables or disables supernetting.
If supernetting is globally enabled, the system can learn routes with a route mask less than 8 bits. Routes with a mask length less than 8 bits cannot have ECMP paths, even if you globally enable the ECMP feature. The default is disabled.
UdpCheckSumEnable
Enables or disables the UDP checksum calculation. The default is enable.
SourceRouteEnable
Enables or disables IP Source Routing globally. It is disabled by default.
ARPLifeTime
Specifies the lifetime of an ARP entry within the system, global to the switch. The default value is 360 minutes.
EcmpEnable
Globally enables or disables the Equal Cost Multipath (ECMP) feature. The default is disabled.
After ECMP is disabled, the EcmpMaxPath is reset to the default value of 1.
EcmpMaxPath
Globally configures the maximum number of ECMP paths.
You cannot configure this feature unless ECMP is enabled globally.
Different hardware platforms can support a different number of ECMP paths. For more information, see VOSS Release Notes.
Ecmp1PathList
Selects a preconfigured ECMP path.
Ecmp2PathList
Ecmp3PathList
Ecmp4PathList
Ecmp5PathList
Ecmp6PathList
Ecmp7PathList
Ecmp8PathList
EcmpPathListApply
Applies changes in the ECMP pathlist configuration, or in the prefix lists configured as the pathlists.
TcpAdjustMssEnable
Note:
Exception: Only supported on VSP 4900 Series, VSP 7400 Series, and XA1400 Series.
Adjusts the TCP maximum segment size (MSS) to improve the throughput for the TCP session over a Fabric Extend (FE) adjacency.
The default varies depending on hardware platform:
  • For XA1400 Series, the default value is enabled when at least one Fabric Extend (FE) tunnel with a MTU less than or equal to 1500 is configured.
  • For VSP 4900 Series and VSP 7400 Series, the default is disabled.
TcpAdjustMssStatus
Note:
Displays the activation status of the MSS adjustment functionality.
On XA1400 Series, the MSS adjustment functionality only activates when at least one FE tunnel with a maximum transmission unit (MTU) less than or equal to 1500 is configured.
TcpAdjustMssType
Note:
Displays if the MSS adjustment value is manually configured or auto-derived.
TcpAdjustMssValue
Note:
Configures the MSS adjustment value.
  • For XA1400 Series, the default value is auto-derived.
  • For VSP 4900 Series and VSP 7400 Series, the default value is 1300.
