You must first onboard the device and configure any optional IQ Agent parameters before you enable IQ Agent.
- In the navigation pane, expand
- Select IQAgent.
- Select the Globals tab.
- Configure optional parameters as required.
- Select Apply.
- Select Enable.
- Select Apply.
Use the data in the following table to use the Global tab to configure the ExtremeCloud IQ Agent.
| Name | Description |
| Enable | Specifies whether IQ Agent is enabled. The default is enabled. |
| Version | Displays the ExtremeCloud IQ Agent firmware version running on the switch. |
| OperStatus | Displays the operational status of ExtremeCloud IQ Agent on the switch. |
| ServerAddressType | Specifies the address type of the ExtremeCloud IQ server address. |
| Server/Address | Specifies the ExtremeCloud IQ IPv4 address or DNS name. The default is hac.extremcloudiq.com. |
| ServerAddressOrigin | Specifies the origin for the ExtremeCloud IQ server address:
| Address | Specifies the proxy IPv4 address or DNS name. |
| TcpPort | Specifies the TCP connection port. |
| UserName | Specifies the proxy server password. |
| Password | Specifies the proxy server username. |
| AssociationUrl | Displays the association URL of ExtremeCloud IQ. |
| PollUrl | Displays the poll URL of ExtremeCloud IQ. |
| MonitorFreq | Displays the monitoring frequency, in seconds, of ExtremeCloud IQ. |
| PollFreq | Displays the polling frequency, in seconds, of ExtremeCloud IQ. |
| LastOnboardTime | Displays the last onboard time of ExtremeCloud IQ. |
| LastPollStatus | Displays the last poll status of ExtremeCloud IQ. |
| LastPollTime | Displays the last poll time for a successful attempt. |
| LastMonitorStatus | Displays the last monitoring status of ExtremeCloud IQ. |
| LastMonitorTime | Displays the last monitor time for a successful attempt. |
| LastHealthStatus | Displays the last health status of ExtremeCloud IQ. |
| LastHealthTime | Displays the last health time for a successful attempt. |
