Configure multicast stream limitation to limit the number of concurrent
multicast streams on the port. Limit the number of streams to protect
the bandwidth on a specific port and control access to multicast streams.
On the Device Physical
View tab, select a port.
In the navigation pane,
expand the following folders: .
Click IP.
Click the IGMP tab.
In the StreamLimitEnable
field, select the Enable option
button.
Configure the maximum
number of streams.
Click Apply.
