Use the following commands to display IGMP information.
enable
show ip igmp interface [gigabitethernet {slot/port[/sub-port][-slot/port[/sub-port]][,...]}][vlan <1-4059>[vrf WORD<1–16>][vrfids WORD<0–512>]
Ensure that the output displays snoop-spb under MODE.
show ip igmp cache [vrf WORD<1–16>][vrfids WORD<0–512>]
show ip igmp group [count][group {A.B.C.D}][member-subnet {A.B.C.D/X}] [vrf WORD<1–16>][vrfids WORD<0–512>]
show ip igmp sender [count][group {A.B.C.D}][member-subnet {A.B.C.D/X}][vrf WORD<1–16>][vrfids WORD<0–512>]
show ip igmp snoop-trace [group {A.B.C.D}][source {A.B.C.D}][vrf WORD<1–16>][vrfids WORD<0–512>]
Switch:1#show ip igmp interface
                         Igmp Interface - GlobalRouter
       QUERY              OPER            QUERY   WRONG              LASTMEM
IF     INTVL STATUS VERS. VERS QUERIER    MAXRSPT QUERY JOINS ROBUST QUERY   MODE   L2ISID
V100   125    activ  2     2   0.0.0.0    100     0     0     2      10      snoop-spb 1100
1 out of 1 entries displayed
                                             Switch:1#show ip igmp interface vlan 2
                                  Vlan Ip Igmp
VLAN QUERY QUERY ROBUST VERSION LAST  PROXY  SNOOP  SNOOP    SSM    UPnP   FAST   FAST
ID   INTVL MAX                  MEMB  SNOOP  ENABLE ORIGIN   SNOOP  FILTER LEAVE  LEAVE
           RESP                 QUERY ENABLE                 ENABLE ENABLE ENABLE PORTS
2   125   100   2      2       10    false   false   RADIUS   false   false   false
VLAN SNOOP   SNOOP           DYNAMIC   COMPATIBILITY EXPLICIT UPnP
ID   QUERIER QUERIER         DOWNGRADE MODE          HOSTS    FILTER
     ENABLE  ADDRESS         VERSION                 TRACKING ADDRESS
2   false   0.0.0.0         enable    disable       disable  239.255.255.250/32
                                             Switch:1#show ip igmp group
                           Igmp Group - GlobalRouter
GRPADDR         INPORT          MEMBER          EXPIRATION TYPE       L2ISID
224.5.2.1       V701-1/4        62.0.1.1        214        Dynamic    40400
224.5.2.2       V702-1/4        62.0.2.1        221        Dynamic    40400
224.5.2.3       V703-1/4        62.0.3.1        217        Dynamic    40400
224.5.2.4       V704-1/4        62.0.4.1        223        Dynamic    40400
4 out of 4 group Receivers displayed
Total number of unique groups 2
               Switch:1#show ip igmp sender
                           Igmp Sender - GlobalRouter
                                           PORT/
GRPADDR         IFINDEX    MEMBER          MLT        STATE           L2ISID
233.252.0.1    Vlan 501   192.2.0.1      spb        NOTFILTERED
233.252.0.2    Vlan 501   192.2.0.1      spb        NOTFILTERED
233.252.0.3    Vlan 501   192.2.0.1      spb        NOTFILTERED
233.252.0.4    Vlan 501   192.2.0.1      spb        NOTFILTERED
233.252.0.5    Vlan 501   192.2.0.1      spb        NOTFILTERED
233.252.0.6    Vlan 501   192.2.0.1      spb        NOTFILTERED
233.252.0.7    Vlan 501   192.2.0.1      spb        NOTFILTERED
233.252.0.8    Vlan 501   192.2.0.1      spb        NOTFILTERED
233.252.0.9    Vlan 501   192.2.0.1      spb        NOTFILTERED
233.252.0.10   Vlan 501   192.2.0.1      spb        NOTFILTERED
10 out of 10 entries displayed
               Switch:1# show ip igmp snoop-trace
                           Snoop Trace - GlobalRouter
GROUP              SOURCE             IN     IN         OUT    OUT        TYPE
ADDRESS            ADDRESS            VLAN   PORT       VLAN   PORT
233.252.0.1        192.0.2.6         500    1/1        500    1/5        ACCESS
233.252.0.10       192.0.2.7         500    1/1        500    1/10       ACCESS
