Use this procedure to view the ingress port-rate limit statistics. The system displays the statistics of the dropped packets and bytes.
This procedure is not supported on VSP 4450 Series and VSP 8600 Series.
Switch:1# show interfaces gigabitethernet statistics rate-limiting 1/1
                   QOS Interface Ingress Rate-Limiting Stats
PORT     DROPPING          DROPPING          DROPPING          DROPPING
         PKTS RATE         BYTES RATE        PKTS              BYTES
1/1		 9224						9260507           		1430758           		1436481032
Use the data in the following table to use the show interfaces gigabitethernet statistics rate-limiting command.
| Variable | Value |
| {slot/port[/sub-port][-slot/port[/sub-port]][,...]} | Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port. |
