| Feature | Product | Release introduced | Release deprecated |
| File Transfer Protocol (FTP) server and client (IPv4) | VSP 4450 Series | VSP 4000 4.0 | Not Applicable |
| VSP 4900 Series | VOSS 8.1 | Not Applicable | |
| VSP 7200 Series | VOSS 4.2.1 | Not Applicable | |
| VSP 7400 Series | VOSS 8.0 | Not Applicable | |
| VSP 8200 Series | VSP 8200 4.0 | Not Applicable | |
| VSP 8400 Series | VOSS 4.2 | Not Applicable | |
| VSP 8600 Series | VSP 8600 4.5 | Not Applicable | |
| XA1400 Series | VOSS 8.0.50 | Not Applicable | |
| File Transfer Protocol (FTP) server and client (IPv6) | VSP 4450 Series | VOSS 4.1 | Not Applicable |
| VSP 8200 Series | VOSS 4.1 | Not Applicable | |
| VSP 8600 Series | VSP 8600 6.2 | Not Applicable | |
| XA1400 Series | Not Supported | Not Applicable | |
| Hypertext Transfer Protocol (HTTP) and Hypertext Transfer Protocol Secure (HTTPS) (IPv4) | VSP 4450 Series | VOSS 4.1 | Not Applicable |
| Hypertext Transfer Protocol (HTTP) and Hypertext Transfer Protocol Secure (HTTPS) (IPv6) | VSP 4450 Series | VOSS 4.1 | Not Applicable |
| Remote Login (Rlogin) server/client (IPv4) | VSP 4450 Series | VSP 4000 4.0 | VOSS 8.2 |
| VSP 4900 Series | VOSS 8.1 | VOSS 8.2 | |
| VSP 7200 Series | VOSS 4.2.1 | VOSS 8.2 | |
| VSP 7400 Series | VOSS 8.0 | VOSS 8.2 | |
| VSP 8200 Series | VSP 8200 4.0 | VOSS 8.2 | |
| VSP 8400 Series | VOSS 4.2 | VOSS 8.2 | |
| XA1400 Series | VOSS 8.0.50 | VOSS 8.2 | |
| Rlogin server (IPv6) | VSP 4450 Series | VOSS 4.1 | VOSS 8.2 |
| VSP 8200 Series | VOSS 4.1 | VOSS 8.2 | |
| XA1400 Series | Not Supported | VOSS 8.2 | |
| Rlogin client (IPv6) | VSP 4450 Series | VOSS 7.0 | VOSS 8.2 |
| VSP 7200 Series | VOSS 7.0 | VOSS 8.2 | |
| VSP 8200 Series | VOSS 7.0 | VOSS 8.2 | |
| VSP 8400 Series | VOSS 7.0 | VOSS 8.2 | |
| VSP 8600 Series | VSP 8600 8.0 | Not Applicable | |
| Remote Shell (RSH) server/client | VSP 4450 Series | VSP 4000 4.0 | VOSS 8.2 |
| Secure Copy (SCP) Note:
                                     The switch does not support the WinSCP client. | VSP 4450 Series | VSP 4000 4.0 | Not Applicable |
| VSP 7200 Series | VOSS 5.0 | Not Applicable | |
| VSP 8400 Series | VOSS 5.0 | Not Applicable | |
| Secure File Transfer Protocol (SFTP) server (IPv4) | VSP 4450 Series | VOSS 4.2 | Not Applicable |
| VSP 8200 Series | VOSS 4.2 | Not Applicable | |
| Secure File Transfer Protocol (SFTP) server (IPv6) | VSP 4450 Series | VOSS 4.2 | Not Applicable |
| Telnet server and client (IPv4) | VSP 4450 Series | VSP 4000 4.0 | Not Applicable |
| Telnet server and client (IPv6) | VSP 4450 Series | VOSS 4.1 | Not Applicable |
| Trivial File Transfer Protocol (TFTP) server and client (IPv4) | VSP 4450 Series | VSP 4000 4.0 | Not Applicable |
| TFTP server (IPv6) | VSP 4450 Series | VOSS 4.1 | Not Applicable |
| TFTP client (IPv6) | VSP 4450 Series | VOSS 7.0 | Not Applicable |
| VSP 7200 Series | VOSS 7.0 | Not Applicable | |
| VSP 8200 Series | VOSS 7.0 | Not Applicable | |
| VSP 8400 Series | VOSS 7.0 | Not Applicable | |
| Secure Shell (SSH) server (IPv4) | VSP 4450 Series | VSP 4000 4.0 |
| VSP 4900 Series | VOSS 8.1 | |
| VSP 7200 Series | VOSS 4.2.1 | |
| VSP 7400 Series | VOSS 8.0 | |
| VSP 8200 Series | VSP 8200 4.0 | |
| VSP 8400 Series | VOSS 4.2 | |
| VSP 8600 Series | VSP 8600 4.5 | |
| XA1400 Series | VOSS 8.0.50 | |
| Secure Shell (SSH) client (IPv4) | VSP 4450 Series | VSP 4000 4.0 |
| Secure Sockets Layer (SSL) certificate management | VSP 4450 Series | VOSS 4.1 |
| VSP 8200 Series | VOSS 4.1 | |
| SSH server (IPv6) | VSP 4450 Series | VOSS 4.1 |
| VSP 8600 Series | VSP 8600 6.2 | |
| XA1400 Series | Not Supported | |
| SSH client (IPv6) | VSP 4450 Series | VOSS 7.0 |
| VSP 7200 Series | VOSS 7.0 | |
| VSP 8200 Series | VOSS 7.0 | |
| VSP 8400 Series | VOSS 7.0 | |
| VSP 8600 Series | VSP 8600 8.0 | |
| SSH client disable | VSP 4450 Series | VOSS 6.0 |
| VSP 7200 Series | VOSS 6.0 | |
| VSP 8200 Series | VOSS 6.0 | |
| VSP 8400 Series | VOSS 6.0 | |
| SSH key sizes in multiples of 1024 Note:
                                     VOSS Releases 6.0 and 6.0.1 do not support this change. | VSP 4450 Series | VOSS 5.1.2 |
| VSP 7200 Series | VOSS 5.1.2 | |
| VSP 8200 Series | VOSS 5.1.2 | |
| VSP 8400 Series | VOSS 5.1.2 | |
| VSP 8600 Series | VSP 8600 6.1 | |
| SSH rekey | VSP 4450 Series | VOSS 5.1 |
| VSP 7200 Series | VOSS 5.1 | |
| VSP 8200 Series | VOSS 5.1 | |
| VSP 8400 Series | VOSS 5.1 | |
| XA1400 Series | VOSS 8.1 |
The client-server model partitions tasks between servers that provide a service and clients that request a service.
For active CLI clients, users initiate a client connection from the switch to another device.
Both FTP and TFTP clients are supported by the switch. The switch does not launch FTP and TFTP clients explicitly as a separate command; you can launch them through the CLI copy command. If you have configured the username through the boot config host command, the FTP client is used to transfer files to and from the switch using the CLI copy command; If you have not configured the username, the TFTP client is used to transfer files to and from the switch using the CLI copy command.
Configuring the boot config flags ftpd or boot config flags tftpd enables the FTP or TFTP Servers on the switch.
For non-active clients, the client exists on the switch and the switch console initiates the request, with no intervention from users after the initial setup. For instance, Network Time Protocol (NTP) is a non active client. The switch initiates the client request to the central server to obtain the up-to-date time.
