Displays the IS-IS logical interface IPsec ID and authentication keys.
Use the following procedure to display the IS-IS logical interface IPsec ID and authentication keys.
show isis logical-interface ipsec
Switch:1>show isis logical-interface ipsec
                          ISIS Logical Interface IPSec
ID   Status   Auth-Method   Auth-Key  ESP                  Responder-Only   Remote NAT IP  Auth-Key-Len Compression Frag-before-encrypt
1    Enable   RSA-SIG       ******    aes128gcm16-sha256   False            -              128          False       True
 1 out of 1 Total Num of Logical ISIS interfaces
                           IPSec Tunnel General Info
       IPSec tunnel global source-ip-address : 203.0.113.1
                               ISIS IPSec Tunnels
ID    IPSec source    IP            IPSec Dst Ip        TUNNEL_NEXT_HOP
      type            address                           PORT/MLT   VLAN        VRF
1     global          203.0.113.1   100.100.100.6      Port1/6    100       GlobalRouter
