Configure IS-IS accept policies on a VRF to use inter-VRF accept policies in the SPB cloud. You can use IS-IS accept policies to redistribute routes between different VRFs, including the global routing table (GRT). First you apply the filter, and then you match the filter based on the I-SID, which represents the Layer 3 VSN context.
                    The isis apply accept [vrf WORD<1-16>] command can disrupt traffic and cause temporary traffic loss. After you apply isis apply accept [vrf<1-16>], the command reapplies the accept policies, which deletes all of the IS-IS route,s and adds the IS-IS routes again. You should make all the relevant accept policy changes, and then apply isis apply accept [vrf WORD<1-16>] at the end.
                    If you use the accept command for inter-VRF routes based on the remote I-SID, the device only accepts routes coming from remote BEBs. For instance, if a local Layer 3 VSN exists with the same I-SID, the device does not add the local routes. The assumption is that the device uses existent methods, either through use of another protocol or static configuration, to obtain those routes.
                    If the route policy changes, you must reapply the IS-IS accept policy, unless it was the last sequence in the configuration.
                    Enable IS-IS globally.
                    Ensure that a route policy exists.
                    Ensure that the VRFs exist.
                    You must configure a route-map to apply.
Configure Inter-VRF accept policies on a VRF:
Switch:1>enable Switch:1#configure terminal Switch:1(config)#router vrf green Switch:1(router-vrf)#isis accept i-sid 100 Switch:1(router-vrf)#isis accept i-sid 100 enable Switch:1(router-vrf)#exit Switch:1(config)#isis apply accept vrf green
Variable definitions
The following table defines parameters for the ip isid-list command.
| Variable | Value |
| WORD<1-32> | Creates a name for your I-SID list. |
| <0-16777215> | Specifies an I-SID value. |
| list WORD<1-1024> | Specifies a list of I-SID values. For example, in the format 1,3,5,8-10. |
The following table defines parameters for the isis accept command.
| Variable | Value |
| adv-rtr <x.xx.xx> | Specifies a specific advertising BEB in which to apply the IS-IS accept policy to routes for a specific advertising BEB. x.xx.xx specifies an SPBM nickname. The system uses the default global filter unless a filter for a specific advertising BEB exists, in which case the system applies a more specific filter. The system requires an explicit filter to redistribute routes from a particular VSN. If the default global filter or the filter for a specific advertising BEB does not exist, the system does not redistribute the routes from the remote VSN. |
| enable | Enables the IS-IS accept policy. |
| i-sid <0-16777215> | Configures the I-SID to which the IS-IS accept policy applies. An I-SID value of 0 represents the global routing table (GRT). |
| isid-list WORD<1-32> | Configures a list of I-SIDs to which the IS-IS accept policy applies. An I-SID value of 0 represents the global routing table (GRT). |
| route-map WORD <1-64> | Specifies a route policy. You must configure a route policy earlier in a separate procedure. |
The following table defines parameters for the isis apply accept command.
| Variable | Value |
| vrf WORD<1-16> | Specifies a specific VRF instance. |
