Use this procedure to globally enable Application Telemetry so it can send packets to an Analytics Engine. By default, Application Telemetry is globally disabled.
You must complete the following:
- Configure an agent IP address.
- Enable sFlow.
- Configure Collector 1.
- Click Application Telemetry.
- Click the Globals tab.
- Select the AdminEnable check box.
- Click Apply.
Use the data in the following table to use the Globals tab.
| Name | Description |
| AdminEnable | Shows whether Application Telemetry is enabled. By default, the check box is not enabled. |
| ClearCounterStats | Clears the Application Telemetry status counters. |
